HELP cant enable duel moniter
coolazn
i have 2 30 inch lcd.
1 works and the other is blank
both screen works when booting but 1 turns off when i enter windows
i have vista all updated with a 7950gx2
i get this message on th einvidia control panel when i try to enable 2 lcd
only one display can be used when multi-gpu mode is enabled
You have SLI turned on. SLI on that card will only output to one display at a time.
so you have one monitor that works and the other doesn't?
well, there is a simple solution for that, you can give me other monitor, i´ll make good use of it ;)
