HELP!!!! - can't disable CPU flex ratio!
Lukin4u
PLEASE HELP!!!!
I am trying to overclock (i even followed the Gigabyte instructions) but CPU is getting throttled by the CPU Flex Ratio
i change the CPU multiplier and the CPU frequency showed correctly, but changing the CPU Flex Ratio makes no difference. Its always 38 and CPU at 3.8ghz.
Product Name: GA-Z270X-Gaming K5 (1.0) BIOS Ver: F5 - updated via APP (which doesnt work btw - easytune had to be manually dl and is all grayed out so cant OC there either) Brand: GIGABYTE Model: i5 7600k Operating System: Win 7 64-bit Brand: Corsair Memory Part No.: DDDR4
CPU Flex Ratio Override -- if disabled, CPU still 3.8 CPU Flex Ratio Settings -- make no difference
Please HELP!!!!
