Wow, I really screwed myself over a stupid mistake.... The unistallation of Nforce2 drivers while thinking that XP will default on generic drivers. The twist is that I used DriverCleaner 2 to clean up all the traces of Nforce2 Files.
Now, it boots into XP, but returns an error saying that one of the nv files are either missing or corrupt. Is there anything I can do to remedy this critical problem? There are some important files I need for school thats on there.....
I have Lindows on my secondary hd, but I cannot access the NTFS partition for some reason. I'm a Linux Newbie, so no help there.
I'm able to boot using the XP Pro Disc and enter into "repair" mode. I have access to the hd under C:/WINDOWS/, but I have no idea how to use this advantage to reinstall nvidia drivers or to do something to recover anything. It's in a pure-DOS environment.
Hopes this is enough info....
I need to backup more often..... Damn it.
