This is fantastic but I'm almost too embarrassed to post this first part. On the Realtek Sound Manager there is a small folder which you can click (I didn't know it) and when you do it says, "Connector Settings." After fiddling with these the sound works through my headsets. The wierd part is that it doesn't matter what I select in either of the two check boxes, the top one is labeled "Disable front panel jack detection," and the other "Enable auto popup dialog when device has been plugged in," nothing changes. Sheesh, maybe I did something else I don't realize. Either way, plugging in the front jack still does not mute the rear speakers but now at least I can turn down the speakers and turn the headsets up for gameplay without waking the entire house.
Second, on a whim I tried re-connecting my build to the monitor using the dvi cable and VOILA! The dvi port didn't blow on the monitor after all. It must have been old/bad drivers. I am in hog heaven.
Thanks for your kind assistance and patience.
