Help buyin mobo/cpu
badbadtz560
Basically, I need a MB with IEEE1394 (for catching video), PCI-Ex16 (for video card), SATA (for WD740 raptor, I need at least 3 HDs), DDRII
Do you know which AMD CPU is competitive to Intel P4 630 3.0G? Is that Athlon 64 3200+? Because I found their prices are similar.
I had chosen few MBs, could you give me some advice? or would another company's mobo be better? like DFI or something?
Intel CPU LGA775
P5GD2 Premium (915P)
P5GDC Deluxe (915P)
P5GDC-V Deluxe (915G)
AMD CPU S939
A8V-E Deluxe (VIA K8T890)
A8N-SLI (nVidia nForce4 SLI)
A8N-SLI Deluxe (nVidia nForce4 SLI)
If you really want to use DDR2 (Which I assume is what you mean by "DDRII"), your only option is Intel right now.
However, if you wait a few months, AMD should be launching their new socket, M2, which will utilize DDR2.
