okay guys, so my q9550 and dark knight came in today and i took out the old processor which was a e2180 and put in the quad after i installed the back plate. put a little artic silver 5 on the heat pipes and put the cooler on. Installed two fans and reconnected everything.
Went to power up and got 8.8. code. Powered on but nothing else. Then i smelled a burnign sent so i immediately switched everything off. Took the cooler off and took the cpu out and nothing looked burnt or smelled anymore. Resinstalled everything and went to power on and post code 8.8. again. No smell just the post code. Power comes on and powers hard drives and fans but not video or anything.
so i went to install the old processor to make sure it was a problem with the new processor and again nothing just 8.8. and no video. I have also tried numerous cmos resets.
I have been working on it for like two hours so I havent had that much time to play around with everything but right now i am in panic mode and need help. The mother board is a dri X-38 T2R..
If theres anything i forgot just let me know. thanks
