ShamrockJack
- May 29, 2008
Thanks to everyone on the forum, this is my first post but I have been reading the forums for some time and you all have been of invaluable help in choosing the components for the system I am attempting to build.
Attempting being the key word - I have put it together and turning on the power results in an entirely unimpressive nada. I need some of the expert help here to dig out of my hole.
First - A list of the components I am using
Power Supply - Corsair TX750
Case - Antec 182
Motherboard - Abit IP35pro
Memory - OCZ DII800 Reaper (2X2GB)
CPU - Q6600
Cooler - XIGMATEK|HDT-S1283 R
Vid - EVGA 9800GTX
DVD - SAMSUNG|SH-S203N SATA
HDD - WD Caviar SE16 3.5in HD-WD6400AAKS 640GB 3.0Gb/s SATA
So - I happily assembled the rig and when I plugged it in, I got a big old helping of dissapointment. No fans spinning, nothing on the monitor ( Syncmaster CRT) - Only a red LED on the board indicating power and a 0.1. code on the onboard diagnostic window. If I hit the power button that is on the motherboard, Fans start up and a number of codes start to run through the Diagnostic window but it finally settles on FF which apparently stands for a good boot. However, I still do not get an image on the monitor. The funny thing is that the indicator light on the front of the monitor has changed from amber (standby) to green ( active - Usually).
Any ideas, thoughts, or oversights? I can use any help I can get and if I left out any info that would be helpful, let me know and I will update the info.
I have updated components before but never tried to build from scratch so any mistake is possible. No mistake is too basic and no item is too big to overlook.
Help me Obi-Wan, your my only hope!
Case - Antec 182
CPU - Q6600
Vid - EVGA 9800GTX
