Hey all, I need some help working out a watercooling setup to go along with the phase change system that I'm looking into getting from Jinu117.
I'm not experienced in this area at all, but I've been reading and trying to learn, but it's a bit complicated
Since the phase change will be taking care of my CPU, I'd like to watercool all of the other hot components. I guess a list of the parts that will be in the rig would help:
Case: Lian-Li V-2000B with Jinu117's custom phase change in the lower section
Mobo: Either DFI Lanparty Expert or Asus A8N32-SLI
Proc: The Opteron 170 in my sig.
RAM: 2GB Corsair PC4000 or 4400
Video: Dual 7800GTXs which I plan on OCing as well.
HDD: WD 150GB Raptor
I think that's all the relevant parts. I'm going to be overclocking this rig as high as it will physically go, so I definately want to WC the chipset and video cards, but would there be any benefit to watercooling anything else (RAM, HD, etc)?
From what I understand, I'll need a radiator with fan(s), pump, blocks, and all the assorted tubing/fittings/etc. I'd like to have a reservoir to make filling/bleeding easier, and I'd prefer it to all fit inside the case if possible. I'm looking for high performance, so I'm not horribly concerned with price as long as it's worth it. Any kind of parts list would be greatly appreciated.
Thanks in advance for the help!
