Hey, all. I've lurked the board a while, checking out the SFF boards in particular, but am not quite knowledgeable enough to be able to chime in with anything. However, I've had a feverish little idea running around in my brain as of late, and I'm hoping you guys can help me determine if it's doable or not. Accordingly, since this is a build/design advice request thread, let me get the particulars out of the way.
1) The purpose of this build is to be a walkaround, 24x7 AR/Personal Assistance computer. I am planning on purchasing and making use of several accessories to make this computer the backbone for a Johnny Mnemonic-style experience, wherein I have my own little private computing right right in front of my eyes. Accordingly the primary uses for this will be AR/Image Processing and Internet useage. While i'd like to do some data processing locally, if I have to outsource it to the cloud, that would be acceptable as well.
2) Budget: I'd like to spend less than $2,000, if possible. I'm already looking at dropping darn near that much for the headgear on this thing, so while on the one hand money is not really an issue, on the other hand I'd like to not spend any more than I absolutely have to.
3) Location: I live in the US, near a MicroCenter, and work near a Frys. So I got that going for me.
4) What I need for that budget: Mobo (fanless if at all possible), memory, hard drive (SSD or other non-spinning media preferred), graphics card (if it is not possible to get dual monitor on mobo integrated gfx chip, or if that will not have enough cojones). Case not included in price, as it will probably need to be custom (see later entries) unless you happen to know of one that will meet the criteria below.
5) No reused parts. All fresh.
6) Mobo features: fanless, dual independent VGA out (if possible), integrated Wifi/Bluetooth (if possible), at least 4 usb ports, preferably more. NIC, while technically optional, is strongly desired. Onboard sound.
7) Resolution: IIRC, output resolution on the Goggles will be 640x480 for each LCD. So I won't need 720 or 1080. I will need multiple, independent VGA output.
8) Space constraints: Here's where I go off the deep end. My ideal plan is to seal this getup inside a Pelican case, to make it waterproof, drop reistant, and ruggedized. Hence my insistence on fanless, with minimal moving parts. Yes, this means the Mobo heat has nowhere to go. No, I'm not sure how to handle that. So far, all I've come up with is a custom completely passive heatsink that extends out of the case through (caulked) holes, radiating out into fins that become cooled by external airflow. It won't look pretty, but maybe I can get it to not look ugly. Unless someone can come up with a better cooling solution.
9) Modding: I am comfy with modding (in case my previous paragraph didn't make that clear), but don't own many tools ATM. Just the basics: screwdriver, leatherman, a pair of snips somewhere. Am planning on investing in a rotary tool, but don't own one yet.
10) Sound: this rig should be as silent as possible.
11) Mobility: very. Again, it's meant to be carried on person, at all times. The smaller the better, though if it has to hide in a shoulderbag or backpack, I can do that.
12) OS: I can provide my own OS, just not sure if I can do what I want with win7 or if I will have to dust off my Linux chops.
13) Timeframe: probably looking at 3-6 months. As much as I'd love to jump right in on this, I can't just pull this kind of money out of thin air.
So, there you have it. Is this in any way feasible, or would I be better off taking the money I would have spent on this, and blowing it on the same flavor of crack I was smoking that gave me this idea in the first place?
Thanks for any help.
