I'll preface this with, yes I know I can save a lot of money if I build it myself.
That being said, I know my skills are lacking as is my time.
I'm willing to pay within reason because good work, craftsmanship, and labor (especially vs. what I can do) are well worth it to me.
Here are some configs I've been messing with and I'd ideally like to upgrade before too long to start enjoying the new games.
I'm working off a 4 year old AGP based system.
Here's the ridiculous fantasy through the roof system that I know I really shouldn't even consider seriously:
I know. I had a good laugh doing that, especially when I saw how much that 9650 added to the price!
Here's something a little more realistic:
I may still go for a P35 or X38 board instead of this regardless of anything else.
Obviously I'd only get one card if I go with a P35 or x38.
^^ There's a few things on that config I'm not sure about, not the least of which is: I think I'd probably skip SLI and get a P35 or x38 Intel board and get one 8800GT or something like that.
I'd rather spend the money on one great card.
I was looking at AVA Direct, Velocity Micro, and Digital Storm, among others.
My 4 year old AGP system was an Alienware that has really done well by me. Back then I had a friend that worked there and that helped the pricing a bit.
Basically I'm all over the place and I don't know where to land and more importantly: When.
I need to sound off on folks and break this whole thing down. I'm suffering from information overload.
Thanks for your time.
GAMING PC, Core 2 Duo DDR2 Gaming System $4359.76 (?!?)
INTEL, Core™ 2 Extreme QX9650 Quad-Core, (awesome but dang expensive! )
# ARCTIC COOLING, MX-2 High-Performance Thermal Compound, Non-Electrical Conductive
# SERVICE, Overclocking, Quad-Core CPU, 10-20% Performance Increase
# ASETEK, LCLC CPU Liquid Cooling System, Socket LGA775/AM2, OEM
# AVA, Coolant, Pitch Black
# GIGABYTE, GA-P35C-DS3R, LGA775, Intel P35, 1333MHz FSB, DDR2/DDR3-1066 8GB/4GB 4/2, PCIe x16, SATA 3Gb/s RAID 5 /8, HDA, GbLAN, ATX, Retail
# CORSAIR, 4GB (4 x 1GB) XMS2 Dominator PC2-9136 DDR2 1142MHz CL5 (5-5-5-15) 2.1V SDRAM 240-pin DIMM, Non-ECC, Heatsink
# eVGA, e-GeForce™ 8800 GT KO 675MHz, 512MB GDDR3 1950MHz, PCIe x16 SLI, DVI /2, HDTV/S-Video Out, Retail
# WESTERN DIGITAL, 150GB WD Raptor® X, SATA 150MB/s, 10000 RPM, 16MB cache
# RAID, No RAID, Independent HDD Drives
# MITSUMI, Black Internal 1.44MB 3.5" Floppy Drive
# LITE-ON, LH-20A1L Black/Beige 20x DVD±RW Dual-Layer Burner w/ LightScribe, SATA, Retail
# COOLERMASTER, CM Stacker 832 (RC-832) Black Tower Case, EATX, No PSU, Aluminum
# CASE FAN, NON-LED, Fans Maximum Package, Low Noise
# SCYTHE, Kama-Meter 4-Channel Fan Controller Panel, 5.25" Bay, Silver/Black/White
# CUSTOM WIRING, Split Loom Wire Management with Round Cables, Black
# THERMALTAKE, Toughpower 850W Power Supply w/ Modularized Cable Management, 24-pin ATX12V EPS12V, Quad +12V, Quad SLI Approved
# MICROSOFT, Windows Vista Home Premium Edition 64-bit, OEM
QTY UNIT PRICE TOTAL
+ GAMING PC, Core 2 Duo SLI Gaming System 1 $3012.40 $3012.40
# INTEL, Core™ 2 Quad Q6600 Quad-Core (SLACR G0 stepping), 2.4GHz, 1066MHz FSB, 8MB (2 x 4MB) L2 Cache, 65nm, 95W, EM64T EIST VT XD, Retail
# ARCTIC SILVER, Arctic Silver 5 Thermal Compound, Polysynthetic Silver
# eVGA, nForce 680i SLI 775 T1, LGA775, nForce 680i SLI, 1333MHz FSB, DDR2-1200 8GB /4, PCIe x16 SLI /2, SATA 3Gb/s RAID 0+1 /6, HDA, GbLAN /2, FW, ATX, Retail
# CORSAIR, 4GB (4 x 1GB) XMS2 Dominator PC2-8500 DDR2 1066MHz CL5 (5-5-5-15) 2.1V SDRAM 240-pin DIMM, Non-ECC, Heatsink
# WESTERN DIGITAL, 150GB WD Raptor®, SATA 150MB/s, 10000 RPM, 16MB cache
# LITE-ON, SHD-16S1S Black 16x48x DVD-ROM Drive, SATA, OEM
# COOLERMASTER, CM Stacker 832 Black Tower Case, EATX, No PSU, Aluminum, SLI Certified
# LOGISYS, Dual Cold Cathode Case Lights Kit, Blue
# THERMALTAKE, Toughpower 750W Power Supply w/ Modularized Cable Management, 24-pin ATX12V EPS12V, Quad +12V, SLI Ready / CrossFire Certified
# MICROSOFT, Windows Vista Home Premium Edition 32-bit, OEM
