Help..boots up but no display
Nash87
Just installed a Gigabyte P35 DS3-R revision 2 mobo and E6850, reconnected the 8800GT and hiper 580watt psu, 4 gigs of ram (2 corsair xms2 ddr2 pc6400 and 2 G.skill ddr2 pc6400), one seagate HD and a dvd-r drive. Connected everything correctly however upon bootup, all the fans are spinning (inluding graphic card fan) but no display on screen. I swapped out my 8800gt and put back my x1900xt and still no display yet the graphic card gets power for the fan so i dont think its the gpu.... I took out all 4 sticks of ram and tried one of each and still no display....this is wierd. Any help would be appreciated.
Also my old rig had fried out my cpu after trying to OC it...i just recycled the same 4 gigs of ram and PSU over while ordering the new mobo and cpu...maybe my ram fried too then thats why no display?...help is appreciated.
Did you OC the ram? Did you raise the memory above the recommended voltage?
all i did was use Easy Tune 5 to OC the proc, i dunno if they automatically up the voltage for the memory sticks as well, i guess the only way to figure this out would be to try out a guaranteed workable ram and see how it goes.. If it's not that i cant see any other reason besides being the PSU ? This is really gay
Try resetting the CMOS and using a PCI video card if you can find one. I had a problem with bios settings a while back wherein if I told the bios to initialize the PCI-E first, I couldn't get video until Vista finished loading. If you can get video from the PCI video card then you can run memtest to rule out memory.
Ok like the tables just turned and everything started working , all i did was just plug in the DVI cable through my monitor a bit further..i guess it was loose. Everything runs great all 4 gigs of ram and such, however i need to reformat my HD and i cannot because at startup my usb keyboard isnt being detected..only works when i go into vista desktop then it starts working.
