Or suggest one if you think one is better.
I want the 14" screen. I would like smaller, but I still want to do some sort of moderate gaming. Also I need it to be as cheap as possible. Would the upgrade in the processor make a noticeable difference or worth it to pay more for a better processor?
http://www.newegg.com/Product/Product.aspx?Item=N82E16834220338
http://www.newegg.com/Product/Product.aspx?Item=N82E16834220391
http://www.newegg.com/Product/Product.aspx?Item=N82E16834220389
