Yesterday I tried to flash my A7V8X to the newest bios, but during the process I got an error prompting me to check a jumper as the flash rom was write protected. As far as I know there is no jumper that write protects the flash rom.
After I rebooted the system would no longer start up and prompts me for a floppy (along with a rapid beeping that stops after you insert a floppy)
I tried following the instructions here:
http://www.nforcershq.com/forum/viewtopic.php?t=3199
The problem I'm having now is getting the autoexec.bat file to run. When I insert the disk with:
awdflash.exe
1008-D.bin
command.com
io.sys
msdos.sys
autoexec.bat
All that runs is awdflash.exe and it gives an error that it can't find the image file. If I delete all the files except awdflash and the bin file I get the same result.
I'm really at a loss...can anyone help?
Q. I flashed with the wrong file. Or my flash was incomplete. Is there any way to recover?
A. If your floppy drive seeks on power up and then stops after a short period of time, you may have a chance to recover. The following information was obtained from Wim's Bios http://www.wimsbios.com/ FAQ's. Corrections on AWARD Bios by Terry McGuire.
Award: The boot-block BIOS will execute an AUTOEXEC.BAT file on a bootable diskette. Copy an Award flasher & the correct BIOS *.bin file on the floppy and execute it automatically by putting AWDFLASH *.bin /sn /py /cc /r in the AUTOEXEC.BAT file. The * would be the correct bios .bin file and there must be spaces between the slash marks. Put it in the floppy and turn on the computer when the floppy seeks it will load the correct bios and reboot by itself. When it finishes you have to remove the floppy and enter the CMOS SETUP and modify the CMOS for your configuration.
awdflash.exe
1008-D.bin
command.com
io.sys
msdos.sys
autoexec.bat
