HELP: ATI tool = blank screen, and Catalyst Control Center does not open
crewkip
I just installed a Sapphire X1600pro in my Dell XPS 210.
I followed all the directions I could find. Disable onboard video, etc.
I tried reinstalling everything from the supplied disc after using driver cleaner to wipe everything out.
When I try to run the catalyst control center nothing happens. No errors, no windows open.
I also installed the ATI tool off of the suggested link in the FAQ section. When I run the tool my computer screen goes blank and says it has lost the signal from the video card.
Not sure what I did wrong here. :confused:
For my system, CCC needs access to the internet or it will not open or even start up after login. Check your firewall. Don't know about ATi Tool because CCC does everything I need.
I am connected to the internet when trying to use it. I wills see if the firewall is holding me back.
I have Net Framework 1 and 2 on my computer so I dont think that is the issue.
In terms of ATI tool, I can run the last beta release before .26. Most of the controls seem to work fine except for Find Max Core. Selecting that causes the screen to go blank. :confused:
Also the temps it was reading seemed pretty high. 66+ with no gaming and it got as high as 93 with ATI tool open.
I get the blank screen and the monitor loses the signal and turns off after the driver loads. This occurs with the visiontek and the sapphire cards. It occurs on the acer 2216wbd and hp p1110 (sony trinitron crt) but they work with a sony 420gs. The weird thing is that I bought the acer because I thought it was a driver problem and the acer worked for three weeks and now nothing will get it to work with the cards anymore (reinstall windows xp and server 2003, different driver sets, tried everything i could think off). I have rmaed the cards.
