Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
dont put AS5 on the ram chips. AS5 can conduct. I'm sure you can download the instructions from the company that makes it. BTW what card are you cooling?
AS5 is very slightly conductive, you'll be ok if you put it on the memory chips as long as you aren't overly generous with it. Just use a small amount and it should be fine.
What do you mean "both sides?" Put a paper thin layer on the chips themselves and rub some onto the raised contact portions of the heatsink. That be all you need!
I'd probably use the silicon paste they provide on the ram, because I doubt it will make any difference, but it would be easy (and dangerous) to get AS5 on the PCB. Silencer doesn't do a whole lot for the RAM anyway. Use AS5 on the core, though.
