Help, Asus P7P55 users
saar
There is a BIOS option on the P7P55D-E Premium, TurboMode 1-2-3-4-Core Ratio Offset, this is what I am intereseted in. There are many versions of the P7P55D available. Could you check the BIOS of your motherboard, (from the following list) and let me know if it exists or not? Thanks in advance.
P7P55D Deluxe
P7P55D EVO
P7P55D PRO
P7P55D
P7P55D Premium
P7P55D WS Supercompter
P7P55D LX
P7P55D-M
P7P55D-E PRO
I'm pretty sure this option exists with the ROG and Maximus lines, but the cheaper the better as far as I'm concerned. I have an i7-875k that will be used for this new build FWIW.
I have an Asus P7P55D-E EVO motherboard; I might have mentioned it somewhere before—I've had it for quite a while, and it wasn't working. Eventually, I discovered a bent pin; I straightened it out, and the board is working now. In the meantime, I also replaced the thermal pads.
The problem now is that while Windows 11 installs and runs fine, the system won't accept any overclocking settings. I have an i5-750 processor and 16GB of DDR3 1600MHz RAM. I used to have Gigabyte boards and knew my way around their BIOS, but this Asus board is completely different; I need help configuring the settings for a 4GHz overclock.
Right now, Windows 11 is running at default settings, and I haven't run any tests yet.
It refuses to accept any overclock; the screen just goes black, and that's it—there are no beeps or error signals.
It runs with Turbo enabled on default BIOS settings. I ran Fire Strike to get a rough idea of the performance. I’ll try overclocking to 4GHz later; I’ve reinstalled Windows 11. Even if I fry the i5-750, I have a spare one. But I have a pretty good cooler, so there shouldn't be any issues at 4GHz—any i5-750 should be able to hit 4GHz.And the motherboard should be robust; it is designed for extreme overclocking.
https://www.3dmark.com/fs/34924760
It has a "CPU Level Up" option:
- i7-860-2.8G
- i7-870-2.93G
- Crazy-3.2G
That Asus has a strange BIOS; Asus has obviously always had unique and distinctive BIOSes.
