HELP Asus p5b plus bios and boot problemb
Penrow
everything was working then after a failed overclock attempt i have to reset the cmos with the jumpers then it will load and say that there was a failed overclock attempt and the time and date is wrong. you have the option to enter set up or load default values, if you load default values then you can load into windows but after reboot hangs on asus boot screen. if you choose the option to enter set-up and reset the time and date and load default values it will hang on asus boot screen.
i have tried flashing bios and removing the battery is there anything else to try any help is greatly apprecciated
yep, yep, got this too once. i will assume since you said you tried flashing the BIOS, that it's the latest from the site (1104, or 1004...I can't recall now). You need to turn the power off at the PSU, either by switch, or pulling the power cord. Pull the BIOS battery, and set the CMOS jumper to the clear position, and DO IT IN THAT ORDER. Wait 5 minutes. Put CMOS jumper back to normal setting, replace battery, and either plug back in PSU, or turn switch to on position (in that order). Power on the system, and then reset your BIOS options. I had to do this when i had pushed the OC too far (I knew the FSB wall on my CPU to be between 395-400, but set it to 433 just to entertain myself...and hope). The BIOS wouldn't come off of the "incorrect overclock, F1 to continue/F2 to BIOS" or whatever the message was. hope it helps.
