- Dec 28, 2006
Ok , here's the issue - I built this machine about 4 months ago and it has run flawlessly the whole time. All of a sudden it just wouldn't turn on one day. I have tried 3 diferent PSUs that are known to work , switched the memory around , reset the cmos , unpluged everything except for the mobo and HDD. When juice is turned on - either by way of switch on the PSU or by switch on the strip , the fans turn on for a split second and then nothing. Unfortunately , there is no diagnostic LED on this board and the power lights(switch) aren't coming on , no HDD activity , the PSU fan isn't even coming on. I even tried a different power switch on the case. I am at a total loss. Is this board fried? Specs below:
Asrock 939Dual-VSTA
2x 256mb DDR
Ultra X2 550 X-Connect
AMD 3800 X2
BFG 128mb Vid card - not sure of model
80GB Seagate PATA HDD
250GB Seagate PATA HDD
NEC DVD/DVDR
Plextor Premium CD/CDRW
I'm really hoping for a simple solution but what else is there to try?
Asrock 939Dual-VSTA
2x 256mb DDR
AMD 3800 X2
NEC DVD/DVDR
