Hi!
Please help me here..
I have a BFG 8800GT card, flashed its bios and loaded the "extra" fields with 700 / 975 / 1700.
Cards works OK.
Question is, will the card work with those clocks @ all times? 2D? 3D?
When I load the Nvidia monitor it always reads 700 / 1950 on my desktop and during the games?
How do I make it go to a lower speed when not gaming?
Just found the answer: (XTREMESYSTEMS)
There is no 2D or 3D mode on the GT. Only a single mode. I think the only way to emulate two modes would be by using Rivatuner but then you can't change the Vcore so it's not worth it IMO.
Thanks!
Cards works OK.
Thanks!
