Help:artic cooling system fo vga
Tank_y2k
hi i just got an artic cooling sytem for my saphire ati radeon atlantis lite retail 128 card but i just notice my card dosent have the socket for powerng the fna but i arnt sendign it bakc cos ital cost more that what i payed for it has any one got any ideas on hpow to over come this
any help would be areciated
We will be more than willing to answer your questions.
And will be fully able to now that [H] is back up.
But PLEASE use the "Preview Post" button and some common sense when typing!
It's much easier to help when your post is readable :rolleyes:
not meant to be a flame or anything like that, just a request for coherence
Sounds like it was a passively-cooled card. Tell us exactly which card you have (you didn't in the first post), and we'll tell you if you can mount this cooler or not.
Making the post readable will help too. :rolleyes:
i have a
Sapphire ATI Radeon 9600 128MB DDR TV-Out/DVI - Lite Retail (GX-025-SP)
Embodying the unbridled dreams of the avid gamer the RADEON™ 9600 ATLANTIS SMARTSHADER™ 2.1 and SMOOTHVISION™ 2.1 technologies construct detail rich worlds peppered with ill-intentioned villains brought to life by DirectX® 9.0 and OpenGL 2.0. Featuring - DVI Out / TV Out, AGP 8x, 128MB DDR memory.
But the problem is it dont have a socket for me to put the power socket in so i cnat power it i was wonderign if there was any other way i could power it
i ahve some spear electritions wire lieing round th hosu and a soilderign iron if theres any wer i could colder the wires to to power it
1) Learn how to type :eek:
2) You could probably splice the 2-wire cable into an ordinary 4-pin Molex connector.
3) Is your particular VGA Silencer a Revision 3 model? If not, then it won't fit on the 9600 series.
it is rev 3 and second
wich one the motex is they the ones u plug into the hdds and stuff
if so shoudl i cuto the red and the black on it ihave a cable in this order that connect to my hdds
red black black yellow
shoul i cut the red and the balck at teh beginign then wire um to my vga silencer
so in other words if i wire it up with the red to the yellow and the black to either of the blacks then i am ok to go
