Help appreciated: CMOS boot screen won't start
ciM2pHat4U
My computer no longer boots up, at all it seems. All the fans/lights start up and the parts make their booting-up noises, but even the CMOS boot screen doesn't come up. I'm pretty sure the monitor connection is not the problem. The keyboard doesn't seem to respond either because the num lock key won't light up when I press it.
Just prior to this problem, I had physically powered off my computer (while it was in windows, idle) by flipping off the psu. The mouse and keyboard weren't responding for some reason, so their was no other way to shut it down. After restarting it, my box started beeping at me, and then it can't seem to start up anymore.
I already tried clearing the CMOS but it didn't help. This thing has me really worried.
Any help is greatly appreciated. Here are some specs: ic7-max3, p4 2.8e, radeon 9800pro, dual seagate sata barracudas. Thanks in advance.
It beeped wildly when I restarted right after the manual shut down, but now it doesn't beep anymore.
edit: After just thinking about it, it no longer does that single beep that accompanies the power up! That must mean the cmos is screwed up right?
Unplug everything that isn't absolutely necessary to boot and try to boot into Windows. Check your connections for your power and reset switch's also.
I did that. All I have connected now are hard drives, video card, and a keyboard. Still no boot up.
edit: RAM is also installed. Corsair xms4000 512mb (x2)
Check to make sure you didn't accidentally switch your psu to European current. And unless you have your hd's setup in a raid, just have the boot disk plugged in. If that doesn't work then try moving it to different sata ports.
Crud, I'm running outta ideas here. :confused:
Everything powers up correctly, and it doesn't even get to the point where it looks for a hard drive anyway, it doesn't do a boot up sequence. I'm out of ideas too. It happened so randomly.
No, but I think I'm going to have to debug the hard way by stripping my mobo of everything. I just really don't want to disassemble and reassemble the kinda complex water cooling system in there.
What is worrying me is that I don't get any error beeping, or any beeping, at all. What could that mean? The mobo isn't detecting anything wrong, yet CMOS just wont start at all. The only thing I can think of is that my beep speaker died (???) which seems ridiculous.
Were you overclocking when this happened?
Most reasonable thing to do first is to clear your CMOS by shorting the jumper which will reset your BIOS to default settings. Unplug your power supply from the outlet before you do this. I know you said you did this already, but are you certain you actually reset it?
If that doesn't help it could be a power issue. What kind of power supply do you have and do you have a lot of brownouts or surges in your area?
Edit: By the way, you don't have to pull the power from the wall or hit the switch on the power supply to turn off your comptuer if it locks up... all you have to do is hold the power button on the front of your computer in for 5 seconds to force a hard shutdown. That's a lot better than yanking the power from your system.
I moved the cmos jumper to clear position for overnight, with the power cable unplugged and the button battery on my mobo removed. The should definately have cleared the cmos right?
I also did a naked mobo test and it wouldn't beep any errors, such as missing the cpu and ram and video card, which strongly leads me to suspect the bios chip somehow went bad. But how does a bios chip just go bad like that? Would it be possible to just replace the bios chip, instead of having to buy a new mobo?
