I have a system which i have just upgraded the memory on, todate i now have a;
P4 2.4GHz (PE PRO motherboard)
2x1G RAM (PC2700)... maximum (PC) i think for this motherboard... this was upgraded from 512MB pc2100.. recently
250G Hard drive
all the usual peripherals ...
System wise, i'm lead to believe this is the most i can get from the 'build'... without changing motherboard or CPU... am i right in my assumption?
I have 2 slots for SDR at PC100 or 133, though i'm not sure what to do with this? whats it used for? will it improve the preformance of my system if i were to obtain sticks for these slots?
Anyone have any recommendations on upgrades .... i've read and heard of over clocking though have never attempted it.... i've also seen on this site members rate there memory timings? how do i go about recording mine... as a method of checking it/improving it....
I'm not to clued up at present on whats out there and available.
Initially i had my system custom built to run GA's, so i needed a fast system, and i did at the time (3yrs ago)... this i know is well out of date hence an upgrade of 'high calibre' is what i'm after....
Any advice recommendations would be appreciated based on the above or opinion...
Thanks
Mason
250G Hard drive
Thanks
Mason
