Put a new rig together in March (see sig) and everything came together nicely. I received a replacement chipset HSF from Asus because mine was way too loud. Apparently they have a new chipset HSF for this board because the original one has a history of failing.
Here are the sequence of events...
10pm: Everything running like normal. I shut off the computer to do the chipset HSF swap. Take out the mobo and replace the chipset HSF. This required me to take every card out of the mobo and unplug everything. I also rearrange some power cables for airflow purposes.
10:15pm: Put everything back in the case exactly as I found it. I try to boot it up and everything seems good. HDDs spin up, fans spin up, internal speaker makes the standard singal beep, and the monitor warms up ("bong" sound with the following static sound). The problem is there isn't any video. The keyboard lights are on and I can toggle them for about 20 seconds then they freeze. The computer sounds like it is running normally but no video at all.
10:30pm: Reset CMOS and try again. Same problem.
10:32pm: Test the monitor with another computer. Works fine.
10:35pm: Reseat all cards and try again. Same problem.
10:40pm: Try switching the EZ SLI Select plug and clearing CMOS. Same problem.
10:45pm: Remove the RAM and try to boot. The Asus Voice Boot thing tells me I am missing memory. So that tells me the mobo is at least working.
10:50pm: Remove all non-essential items and try to boot. Same problem.
11:00pm: Cry myself to sleep.
Anyone have any ideas? I am pulling my hair out...
AMD64 3500+ Winchester (Stock)
ASUS A8N-SLI Deluxe (Bios 1006)
XP-90 HS w/ Panaflow 92mm fan
Corsair Value Select (512Mx2)
eVGA 6800GT
Antec NeoPower 480
Audigy 2 ZS Gamer
WD 74gig Raptor
NEC 3520A
CoolerMaster WaveMaster (Black)
Logitech Z-5500 5.1 speakers
eVGA 6800GT
Antec NeoPower 480
Audigy 2 ZS Gamer
WD 74gig Raptor
NEC 3520A
