So i'm going to upgrade my current system, which sits like this :
2000+
512mb PC3200
KD7
2 X 40GB
R9800pro
10X sony burner
16X DVD
48X external artec burner
I'll be adding these things :
mobile 2500+
another 512mb pc3200
custom made case (wait till you see it
WATERCOOLING.
I need some help with the watercooling planning part, as I've never ventured into this before. I'll be running two powersupplies, one for the water & opticals, one for the system & HDD's. That I can probably take care of. What I would really like to know is how I'd set up the cooling system If I wanted to watercool jut the CPU versus the CPU & GPU.
rad before blocks? rad after blocks? how many gph? which way should the flow go? duh? what would a flow diagram look like for all three options?? (cpu only/cpu+gpu/cpu+gpu+chipset)
So far I'm looking at buying all my parts @ bigfoot.com, so what is the temp difference when looking at something like
this or something like this or something like this ?
2000+
512mb PC3200
KD7
2 X 40GB
R9800pro
10X sony burner
16X DVD
mobile 2500+
WATERCOOLING.
