superkdogg
- Oct 14, 2004
Hi all,
Basically as a learning experience, I am building an old, not very good file server on the cheap.
So far I have a Tyan Thunderbolt Dual P3 mobo with two 450 Mhz cpu's OC'd to 504 in it and 512 MB of ram. It's currently using a simple IDE-only setup and everything's peachy.
Now is the SCSI part and the complications:
1. I know absolutely JACK about SCSI
2. I came across what seemed like a deal on eBay- (5) 9.1 GB 10K Cheetahs (early generation) for $28. So now that they are on the way, I realized that I have no clue how to set up this beast
The drives are 80 Pin wide-ultra scsi-SE or SCA (seemingly used interchangably in the documentation, but I don't know). The board's onboard SCSI is 68 Pin up to 80 MB/s, so I think that makes it wide-ultra SCSI2 (or not). The drives come complete with the hot-swap carriages and they appear to have some sort of adaptor sticking out the back that looks like and ISA interface (I'm sure it's not, but it has big, wide pins). Anybody know what that's about?
The goal is simply to get all 5 (or four of five if that would be better/easier/cheaper) working as simply as possible. The main problem that I see is getting 5 80 pin drives talking to a 68-pin controller. 80 pin cables are evidently hard to come by and 80-68 pin adapters are more $ than I want to spend on this project. Would it be possible to find and 80 pin cable or two and use only one adaptor on the cable where it attaches to the mobo? So the only 80-68 conversion would be at the SCSI controller as opposed to 5 conversions, one at each drive?
Secondary question: (Warning: This may be a really stupid question) Would it be possible to wire an old AT psu to make an independent power source for the drives? That way I could build a small chassis to contain them and the psu and not take space or power from the current setup. This is not a need, just a "for instance."
Like I said, I don't know much about this (read: nothing) and I'm looking to learn, so please let me know what you all think and offer any suggestions....
T[H]anks!
And the new question is....
Since the SCSI controller on my current mobo does not have raid capability, will I need to get one that does or does the backplane give me that functionality by making all the drives installed "appear" to be one since they all use the same physical connection to the scsi bus?
T[H]anks!
