Leadslinger
- Aug 4, 2005
Hi Folks,
I have been scanning these boards for a while now and like how mature the members are around here so I think i'll stick around an learn a few things
I'd like to get a some opinions about a pure gaming system i'm going to build. i'll list everything here, and if anyone has or knows why i should go with different components I sure would appreciate it. I'm not an OC' type of guy since I don't know alot about doing it correctly)
Thermaltake Xaser Armor series black case
Abit Fatal1ty N4 A8N-SLI mobo
AMD FX57 San diego core CPU
OCZ Gold Pc3500 (433hrz) Dual channel Mem (1gig)
Thermalright XP90 HS w/ Panaflow 92mm hydro flow fan (wondered about the "Bigwater" system for an option)
Plextor blk SATA DVD burner
WD Raptor 74g SATA 150 drives x2
Sony 3.5 flop drive
BFG GTX7800OC vid (only one for now) ..will add another for SLI later
Audigy 2 ZS Gamer LE
Silverstone Zeus SST ATX 650w 12v PSU
Win XP pro sp2
I have an older gaming box built around a barton 3000+ on the ASUS A7N8X E deluxe board, but i have never had any luck in getting it to OC (probably because i don't know how to do it right) but it won't post if I use any higher settings than the canned "aggresive" in the bios. I guess my biggest handicap is not knowing what voltages I can tweak safely, even though I been reading alot, it's still really fuzzy to me.
If the xperts here wouldn't mind tossing in they'er 2 cents about whether this "build" would be a good choice in components I would really appreciate the help, Also I'm hoping to avoid costly incapatability issues I may not know about
P.S. will SATA 150 drives work on the SATA II board ?
Thanks for any inputs guys, Cheers
Sorry if this is in the wrong place, but the mobo is the main key component i'm curios about.
Sony 3.5 flop drive
Win XP pro sp2
