Help A Beaner Out!
CrazyBeaner
i currently have this ram and for some reason cpuz is reading my mem in 2T command rate, wat am i doing wrong? im using the reccomended timinings and speed and it says 2T, i am running in dual channel,
HELP!!
you goto bios and then command rate and then change it to 1T, unless your mobo doesnt support it
well i went into the bios and didnt see no command rate thing, wats it called in the bios?
