Hi,
I'm installing a VGA Silencer rev 3 fan on my Radeon 9600. I'm also putting on a bunch of OCZ copper ramsinks. Well, I was hasty and forgot about one detail while installing it...
I removed the passive heatsink using a blow dryer and that went fine. Then, I stuck the ramsinks on. I went to install the VGA Silencer and...
there is no fan power plug on the card!!!
Now, I'm stuck. I can't put my old passive heatsink on w/o removing the ramsinks. I don't want to use it anyway. I want to use the VGA Silencer, but I don't know where to plug the fan in. Is there any way I can get it up and running?
thanks for any help!!!
DCZX
DCZX
