HELP! 8RDA+ onboard LAN causing trouble everywhere
MajinWu
Problem:
This is the SECOND time this has happened. Everytime I plug an ethernet cable into the onboard LAN, my CPU acts up. In task manager, the CPU usage jumps from 0% to 60% back and forth continuously, causing the computer to stutter every 3 seconds. It can't connect online, and WindowsXP can't even shut down correctly(it just hangs there... big surprise eh?). The problem persists when I disconnect the ethernect cable, too.
What caused it:
Again, this is the second time this has happened. I left my ABC Client (a BitTorrent client) running overnight downloading 3 files, and when I come back to check on it in the morning, I find the computer disconnected from the internet and the CPU stuttering. Took me forever to fix it. First I reformatted my harddrive and reinstalled WinXP. Problem still persists (It's Microsoft, so this is to be expected of course...) Then I tried to reinstall the mobo drivers, but the whole system crashes when it attempts to install the Ethernet Drivers. So I went into Bios and disabled onboard LAN. This allowed me to install the drivers successfully. When I turned the LAN back on, everything worked again... for about 3 weeks. Yesterday, the same problem occured the same exact way. Unfortunately, I carried out the same process as before, but it didn't work this time around...
What I've been trying to do:
Well I tried installing drivers that came with the Epox CD, no good. Tried the newest drivers from their website, no good. I tried setting the Fail-Safe Defaults in Bios so that my system runs at 100x12.5... no good. I can't find a place that hosts older Bios's for the mobo, but if I find one, I'll give that a try.
I've been using this motherboard for about a year now, and it's just started acting up in the past 4 weeks. I've had it OCed at 11x200 stable for about 11 months, and just had to running at 10.5x215 for about one month. I have Arctic Silver Alumina on the NB, SB, and Mosfet for cooling reasons, but Alumina isn't conductive. Please help me out!
