Help! 7800 GTX - possibly damaged ram chip
mnemonik23
Hi,
my stupid :rolleyes: little brother "glued" the ramsinks on his watercooled 7800 GTX with arctic thermal adhesive. He tried to remove one of them with screwdriver and I think damaged ramsink or it's pins :(
Card works but of course there are bunch of "colorful squares" on the screen.
Warranty is voided but the thing is that EVGA DOES NOT provide any repairs at ALL! I've contacted them and they told me so.
So now he gave it back to me (it was my card from the very beginning) and it's sitting on the shelf.
What can I do with it?
here the images
Oh man those chips are gone. I done that in the past with my geforce 3 ti 4600. The arctic adhesive is very strong and will rip off the ram chips. You got yourself a keychain :D
Damn... I feel for you.
One time I spilled a dab of Gorilla Glue on a stick of SDRAM, not realizing it, I moved the ram on top of the motherboard it was meant to go in. Let's just say that they were together until death did them apart.
If you decide to scrap it, I'm sure some enthusiast will give you SOMETHING for it in hopes of being able to repair it. The fact that that one chip seems to have come off a tad doesn't bode well for efforts, though.
That was an expensive mistake!
It might be possible to remove the damaged chip and see if the traces on the board were damaged also.If the board was not damaged,unlikely, a new chip could be installed.
Unfortunately you probably do not have the correct equipment for such work.
it's toast.
it would probably cost a ton more to fix it than just to replace the whole thing
sucks :(
If you knew someone with a hot air soldering station it might be possible to just reflow the solder and lay the ram chip back down.
Not very likely to work as the board and the chip are fragile but it would be worth a try
