junglicious
- Nov 24, 2007
Hi,
I am going to be building 4 workstations and one Windows Server 2008. The workstations will run a program called "Furniture Wizard" (inventory/invoice) that does not require much hardware. However I would like these workstation to last 7+ years and able to use other programs we decide to install later. I would also like it to run smooth and fast with no lag or down time. Below is a list I created for the workstations.
The server I don't know what parts I need or should use. Is Windows Server 2008 hard to setup and what hardware is recommend for a server computer? Again I want it to last and run smooth with no down time. I will probably have 3 or more printers hooked up to the network. I was also thinking of using a 128GB SSD drive for the server's OS and have 2-4TB of storage.
Open to recommendations and suggestion. Need this done by the end of April.
Thanks
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
Web, data entry (Furniture Wizard), ms office, email
Under $1,000 per workstation. I don't know how much a server build would cost.
3) Where do you live?
Fresno, CA. No good B&M store at all.
Motherboard, case, PSU, CPU, ram, monitor, keyboard, mouse, os win7 pro x64, hard drive, dvd-r. As for video I was hopping I could just use the iGPU on the CPU hence why I choose an iSeries CPU.
all new parts
6) Will you be overclocking?
no
19"
Before the end of April.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
none of that is needed but don't mind having.
win7 pro x64
Workstation hardware list:
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
Model #:Three Hundred
$69.95
GIGABYTE GA-P67A-UD3-B3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Model #:GA-P67A-UD3-B3
$134.99
CORSAIR Enthusiast Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible ...
Model #:CMPSU-650TX
$119.99
Intel Core i5-2400 Sandy Bridge 3.1GHz (3.4GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52400
Model #:BX80623I52400
$189.99
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
Model #:F3-12800CL9D-4GBRL
$49.99
Western Digital Caviar Blue WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Model #:WD5000AAKS
$49.99
Rosewill RK-7300 Black USB Super Slim Unique Curved Design Multimedia Full-size Keyboard
Model #:RK-7300
$14.99
Hanns·G HW-191APB Black 19" 5ms Widescreen LCD Monitor
Model #:HW191APB
$129.99
Microsoft Wheel Mouse Optical - OEM
Model #
66-00066S
$15.99
LITE-ON 24X DVD Writer Black SATA Model iHAS-324-98B
Model #:iHAS-324-98B
$22.99
Thanks
all new parts
no
19"
win7 pro x64
$69.95
$134.99
Model #:CMPSU-650TX
$119.99
$189.99
$49.99
Model #:WD5000AAKS
$49.99
Model #:RK-7300
$14.99
Model #:HW191APB
$129.99
Model #
$15.99
$22.99
