Hi
My current setup (in sign) is working well but I feel its a bit dated now plus its a three year old installation so it is time to update. Im looking for a system that will last as long (at least aiming for that) as my current setup. So the motherboard is more important than the cpu, which I can update as needed without reinstalling. I understand that Intel is about to launch Nehalem in a few months and AMD is working on AM3, should I wait for these before I buy? If not, what would you recommend today? I've updated my rig slightly, running three monitors and therefor Id like to combine a built in graphiccard and keep my current one as well. Is this possible with the motherboards today? Also looking for some easy overclocking. Is DDR2 the way to go or wait for DDR3?
So what are you guys recommending?
Motherboard
Cpu
Ram (I want 8gb)
Got the rest
Thanks in advance
Edit: Ops I realised this should be in the General forum...Could someone move it? Sorry...
Motherboard
Cpu
Ram (I want 8gb)
Got the rest
Thanks in advance
