mek_nginear
- Oct 25, 2006
I just installed an Orion 585w on my new Opteron 165/Foxconn 6150K8MD system. Seems to be working fine so far- the voltage rails are right where they should be, even with 6 HDD's installed. Interesting, though- I originally bought it MONTHS ago (when Directron had them on sale previously), but when I installed it in a case powering an Abit NF7-S v2.0 (20-pin connector), the computer wouldn't boot (and yes, I separated the end 4-pin connection and properly lined-up the plug). But it worked just fine on the Foxconn, which is a native 24-pin connector mobo. Oh yeah, note that compared to a Fortron 400w FSP400-60PFN, the Orion PSU is a lot lighter in weight, maybe 2/3 that of the Fortron.
Also, a weird thing with the NF7-S, BTW. I own two of them, and both, no matter what PSU I install, show a 12V rail that is rather low, never above 11.5V, even with a barebones setup of components. All reporting utilities say the same thing, 11.37 to 11.5 volts. The sensors installed on the mobo, perhaps? The Orion/Foxconn combination 12V rail is running at 11.97V, which makes me much happier.
