infocalypse
- Jun 14, 2004
Hey peeps,
I've got a pretty nice storage setup at the moment with 4x147GB 10k SCSI drives. Very fast and plenty of room for pr0n.
Naturally, these drives get pretty warm. Not crazy hot, but warm nonetheless. At the moment, I have a single 120mm fan (enermax adjustable, I believe) blowing over these four drives and while they're definitely not overheating, they're still warmer than I'd like. This is a typical setup where the 120mm fan is pulling cool air directly through the front of the case and blowing it over the drives.
In an effort to cool these things down a bit more (and hopefully lower my fan speeds for less noise) I'm going to remove the rubber noise-isolation nubs that prevent them from making metal-to-metal contact the the drive cage, but I'm also thinking about picking up some of those generic stick-on heatsinks (like the type you'd use on memory) to increase the surface area a bit and enhance the cooling provided by the 120mm fan.
Whaddya think? Will it make a difference? Anyone done this before? Am I wasting my time?
