Acording to aquatuning.de EK-NB/SB ASUS 1 will fit both NB and SB.
EK-Mosfet ASUS 1 for the mosfets to make the setup complete and more sexy looking well built wc-blocks you can´t find anywere and not for that price.
If air is the choise for Mosfet/SB then HR-09 U TYPE2 is for I/O Side mosfet
and HR-09 S TYPE2 for Up Side mosfet,
SB will like the HR-05/IFX or HR-05 SLI/IFX, not the regular HR-05 since the list only contain the IFX-versions i listed.
Go to the surplus electronic store and pick up some old 386/486 aluminum/copper heatsinks. Cut to fit your ram and vreg's. Use a Dykem marking pen for the cut surfaces and glue/stick them on.
