Heatsinks for some 5530's
Vaulter98c
[H]ard|DCer of the Month - October 2009
Ok, refund still hasn't come back (no clue why) but I'm getting ready to pick out some heatsinks, these ones are highly rated on newegg and seem to work like a true, but at 92 they are a tad smaller, which should be good for a dual board like the SR2
Think it's a good unit?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Posted via [H] Mobile Device
No. They do not handle OC heat. Troll the heatsink forums, I've seen several complaint threads about the 212+ lately and how they suck at oc heat. They are just not made for it. (compared to others)
Buy a CoGage TRUE Spirit if you want to go cheap (under $50-60). The newer version shipping now in the blue and black box comes with the bolt through kit; you don't need to buy it separately anymore. :)
Honestly I wouldn't bother with anything but a TRUE Spirit, even with the Noctua NH-D14 out. You're looking at a few degrees warmer on the TS, but they are arguably the best bang for the buck coolers you can get (and they are roughly top 5 on temps). You sacrifice a few C on a TS over a D14 but you keep $40 in your pocket. ;) Even better if you pair one with a better fan (I haven't used the fan it comes with, admittedly). Going from my S-Flex E's and Noctua P12's to what I'm running now on mine (high speed Yate Loon D12SH-12), I dropped another 5-6c at load with the Yate.
http://www.hardocp.com/article/2009/07/23/intel_core_i7_heatsink_roundup_q309/5
Thumbs up from the [H] also. :D
funny, that was the one I was looking for but didnt see it on newegg, maybe I just missed it, thats the problem surfing on a phone
Ive got a normal true on my i7 now, but I'm not sure they will fit on a SR2
got links?
Unless thoes HSF have Xeon kits they won't mount anyways.
I think H50s are your best option. They use a threaded mount system to begin with. (I do belive it is compatable but doubble check before you click buy)
+1 on the H50's.
I'm already under water on my rig so I will be sticking to water. I've just got to rework the plumbing so I can cool two CPUs, but other than that, not many changes.
ok, well I'm sitting on my new pair of 5530's (d0) and I was thinking, isnt the h50 kinda big? Where the hell am I gonna put to rads? I'll be benching this rig so no worries about a case but isnt there a good air solution?
Get the H50 floating edition :p
But seriously the reason I looking at H50s for when I get the SR2 is they have a small footprint on the board and you can rig something up for the rads fairly easy.
But since the 5530 is a 80 watt CPU I'm not sure we need the cooling tot he point of a true.
The 5530 is an 80 watt CPU at stock. Going into an SR-2, you're going to OC the crap out of it and it will no longer be an 80W CPU :D
Ohh I know. The thing is your starting at 80 not 130.
You've got 30's don't you too?
And SR2 comes with xeon and i7 mounting plates
I got a venomous for my i7 and I like it. but be carefull of that center bolt!! you can tighten it to much!!! and when you do all kinds of crazy shit happens!!! machine starts to post and boom a bunch of un readable gibberish then shuts down. It was awsome!!!
Up untill the magic white smoke is released :eek:
