Since some days ago, I've noticed the CPU fan is spinning at the max speed (a bit higher than 5200RPM). In some very rare cases it deccelerates, but most of time it's flying.
The CPU and system zones are quite ok. The CPU fan is always at max, don't caring if the system is under high load or not.
I know I should replace my heatsinker with a better one (can you suggest a model? great), but is there something I can do in the meanwhile? I guess this is not a software issue, right? (last thing I've done at hardware-level with the PC: installed a video card).
The vibration is annoying. It's like a thousand of bees in my room. LOL!
