Heatsink superglued to processor?
Xenozx
OK my little brother ran out of AS 5 so he used some superglue.... Just kidding. anyway i just bought a new motherboard and it got delivered today. I just got home from work. took everything out of the case. and started disconnecting the heatsink. both screw's are out but its like the heatsink is stuck on the processor. you can turn the thing upside down and it wont come off. i tried pulling it with enough force without damaging anything. im kinda at a loss as to what to do next. I dont want to break a 400 dollar processor. any idea's? all thats on there currently is AS 5. it looks like it maybe dried up or what ever and got stuck.
Run the system till hot, turn it off then quickly take off the HS. You can twist it side to side careful (so you dont bend the pins) to break the seal and then pull directly upwards. If you dont want to run the PC, use a hair dryer and heat it up then try it.
Hair dryer worked like a charm 8)
thank you
one last question to avoid another post.
When connecting all the cases lights/buttons (reset,power, speaker, etc)
how are you suppose to know which one goes where? like the speark says -spk and +spk and it has an orange and a black cable. which one goes where?
also grounds. i always assumed grounds would be the non colored (either black or white) wires. and the red/green/orange was the other one. am i doing this correctly? any tips?
should be in the motherboard manual if you lost it, you can usually get it from a manufacter's .com. as to the polarity of the connectors to the motherboard try it till it works no one gets them right on the first try ;)
kool, one last question....
sata drives. I had a raid 0 config running in my last rig. can i just pop those drive in with this new motherboard and keep te file system/ windows install intact? or am i gonna have to reformat and resetup a new raid?
format time baby...make sure you have the RAID drivers on a floppy....
