no, heat it up, safest and easiest way to get it offc0ex said:all, thx for the idea of heating it up. Also will freezing work? The p4 is coming off a laptop with a weird heatsink that appears to be stuck. I have another heatsink for the dsesktop that I plan on putting in which will work.
oreo it, takes quite a bit of force, if its a thermal pad you might need to gently pry it off wih your finger nail, do not use a screw driverc0ex said:yea, i tried to freeze it, but it didnt work. I tried that rubbing alcohol and that didnt work. I was wondoring if the size of the heatsink matters?
