Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
If there is plastic on the bottom of the heatink your suppose to peel that off first. What is under the plastic is prolly a thermal material, so you wont have to add paste.
If there is just metal under the plastic when you remove it, you will need to add some kind of thermal paste.
