Heatsink question
MrLoLeR
Why do you prefer the 92mm? The 120mm is quieter and will cool better, with minimal increase in cost.
I believe it will work, since all their LGA775 hold-downs should be the same, but my other point still stands. Unless you don't have space, there's no good reason not to get the 120mm version.
Sorry for posting this in the wrong section. A mod can move it if need be. But yea, i was mainly concerned about case clearance is why.
