Heatsink/heatpipe removal
Jacmac
What's the best way to remove the heatpipe/heatsink assembly off of a motherboard without damaging anything? The assembly looks like it is glued to the chipsets/voltage regulators, there doesn't appear to be any bolts holding it in place. The motherboard is a Striker Extreme.
Just a disclaimer before we start I've not taken the heat sink off of a striker but I have done several other Asus boards, so I cant promise this is how your is set up.
There should be only plastic clips holding you heatsink to the regulators and either plastic or metal clips to the chipset. I've never seen anything glued to the mosphets and it is normaly just setting on top of it. If you take the clips of you should be able to pull the heatsink from the chipset.
Don't pull to hard if it doesn't come off just give it a little twist and it should pop free. The northbridge is generaly not to hard to get free.
gl
