- Jun 9, 2003
Hey guys. Ever since I switched to my Foxconn mobo, I've been having heat issues, with boot temp around 40c or so. I've remounted my Zalman 7000-B CU , but so far it hasn't made too much difference. Looking at the bottom of my zalman, it doesn't look as... uniform? in color as it once did and I'm wondering if this is the problem. Even after cleaning it with ArcticClean, the irregularities still exist.
At this point it seems to me there are two possibilites - the Foxconn just reports high temps (as I didn't have this problem with the previous Biostar board) or something has gone wrong with my heatsink between/during installations. As such, I'm looking for the best heatsink+fan assembly that will fit inside a SG01-E setup. Another Zalman? a Scythe?
Any suggestions? Of course, height is a consideration here as the power supply is right above in this case setup. Thanks
