heatsink for Gigabyte GA-MA770UD3
jdonohue
I have an AMD Phenom 9650, with a Gigabyte GA-MA770UD3 motherboard. I need to replace the stock AMD heatsink and fan. I have OCZ Reaper memory modules with the heat pipes, so I have found it difficult to get a better heatsink with a large fan that will fit on my board, especially with the RAM in the way. Does anyone know of some good heatsinks that will be compatible with my setup?
Thank you
There are various form of heat sink, you may want to try to check this website:
http://www.heatsinkfactory.com/
I have this motherboard and measure the cpu space is 10.2cm x 8.0 cm.
Maybe you may check the heat sink that is vertically in height to avoid contact with memory modules.
