Heatsink for Antec 900
demingo
Trump is My President!
So I have the original Antec 900. Bought a new i7 950 setup and decided to use a Cogage TRUE Spirit since all the reviews were extremely positive.
Turns out... It doesnt fit in the Antec 900. The side panel fan is in the way. I don't want to run without the fan since it does a great job of cooling my chipset/video.
Any reccomendations? Was thinking about a H50 but not sure how its performance is.
You can get an H50 on the forums for 45-50 shipped. They are Great Coolers and it saves a ton of space in your case. I have a Corsair A70 and believe me its Huge. I almost regret buying it
Yes H50 is looking like it going to be it. Gonna grab it at Microcenter today. Bit more than the forums... but the rest of my hardware is here and ready. I wanna get my build done this weekend! :D
i have an antec 900 and to fit my sythe ninja in it with the fan, i just cut corner of the fan off. not sure if that will work for you. other option is just take off the 120mm fan mount and mod in a smaller fan moving it down a little.
