Heatsink for a 2500XP-M Overlclock
pico_uk
I'm looking to do a few upgrades on my PC in the coming weeks. I am looking to get a Sapphire 9800 Pro and a 2500XP-M, I also need to get a new heatsink as my current although pretty good (51 degrees celsius full load), is stupidly loud 35 dB i think. Does anyone have any reccomendations of a cheapish (sub £20 or for the guys across the lake sub $50) heatsink that would be up to the job of an overclock. I've been looking at some thermalrights and solteks but I haven't got money to burn. A possible solution I thought of is to replace the fan on my current heatsink for a panaflo or papst but its rated 2800+ so dont think it will work.
get a slk.. www.svc.com all sub 50 and use a tmd even tho it appears to push less air.. but with a smaller fan most of the air is being shoved through the heat sink and almost no dead zone.. never seen one in person tho
i ran a 80 mm fan on my slk-800 for the longest time.. my friend had a 70mm delta that was deathly quiet from his athlon 64... i gave it a try and got better temepratures then i did with the 80 with equal ammount of noise (my comp cant be hered above the crickets outside...with the windows closed... :D )
haha my 2500m rules. it's at 3200 with absolutely no vcore increase..
sorry, but i just had to gloat.
Dont go cheap on cooling thats for sure. I find my SP-97 works great, cant get better air cooling then that.
