heatsink/fan for AMD64?
iamnamja
hey guys i would love some recommendations... i was considering zalman... but i'm afraid it might not fit... i want something that cools.. but is also quiet thanks~
I have the zalman, idle temps w/ it on my vantec fan controller on LOW, and only 1 120 in the front, are about 34-36c, and load on full is about 36-42 so far.
no O/C yet thou. let you know how that jazz goes.
not to mention on low you can't even hear it.
wow... that sounds great~ i'm just wondering tho... i'm going to be getting MSI K8N Neo2 Platinum would it fit fine?
I'm also getting corsair XMS... i heard those are higher than normal rams, so it might cause a problem... is this true?
I have a thermalright xp-90 , it keeps my 3000+ a64 under 95F(loaded) when i have it running 2.6ghz. I have it mated to a 80mm thermaltake 5000rpm fan, but most of the time it runs at a much lower speed. It really only kicks in when i'm gaming.
i would go with an XP-90. dont think the 120 will fit. just get yourself a nice 92mm fan, and then you could control it how loud or silent you want it.
i know this is off topic, but, does anyone know the stock fan specs for AMD? i have 754 3400+ ClawHammer, and i couldnt find the info on their website. anyone know?
I would recommend the Cooler Master Hyper 6. Mine's running 30*c idle and about 40*c load. It's amazing.
