Heatsink compatibility list for Shuttle mn31n?
Satyrist
I went and got a mn31n a couple of weeks ago, I was wondering about which heatsinks that use the mounting holes would work on it?
This is a board I'm looking to use in a suitcase modification, (just looking for a nice secure mounted HSF that cools well) is why I'm asking. If there aren't any, I may just go with a Thermalright SK-7 (or equivalent)
For a CPU, I'll be using a TBred B DLT3C 1700+ on it, along with 1GB PC2700 Kingston..undecided between using a 64mb radeon 9100 or the onboard video at this point.
Thank you-
Well, I have that board, and I would just go with the intgrated, it will look cleaner (in the case) and I think it puts up decent numbers for what it is.
There isnt' much space between the NB hsf and the CPU socket, but looking at pix, and comapring, I think it will fit. I have a volcano 9 on mine w/o any problems, and about 1cm to spare.
Hope this helps
I have fit an Alpha PAL 8045T onto my Shuttle AN35N, which is virtually idential to the MN31N from the second PCI slot and up, so you may have luck with it.... There was one close capacitor that the Alpha people didn't figure that it would fit, but it does.
Other heatsinks that I have personally successfully attatched to the MN31N:
Vantec Aeroflow
Thermalright SLK-700
Dynatron heatsinks (stockish type things)
Thermaltake's Volcano 9
AVC's current heatsink (the bundled one w/ boxes)
Others that I don't remember.
I did take a peek at both layouts, they look identical around the cpu socket.
About how close was that one capacitor from the heatsink, btw? Just before I dump $30 on a 8045, to be sure.
Thanks again
Thanks again
It wasn't close enough to make me put a brown stain in my pants wondering how the heck it would fit on. The heatsink hung off the top of the board a very little bit, so if you're putting it in a case with no room above the board, it may be trouble- but i've got it in an ancient POS midtower that doesn't have room for anything, and it works alright (i want to replace it, but the only g/f approved replacement case is a PC60, which i can't budget for right now ;) )
