Heatpipes upside down?
BTex
Hey, I am currently looking into getting a new MB since my Asus A8N-sli has died.
I was looking at an ABIT at newegg and saw a forum post mentioning that the heatpipes don't work in cases like the Lian Li that places the MB upside down.
heres the post
http://www.newegg.com/Product/Product.asp?Item=N82E16813127207
Is this true? Has Lian Li killed more of my equipment? (A previous lian li case I had held the hardrives on their side, they ALL died within 6 months, One continued working when I placed it in a new case horizontally)
So what do you think of this heatpipe deal? I cant see why it wouldn't work unless there is liquid in the pipe. Is there?
I dunno about that. Processor heat pipes don't go up, they go to the side and they work. I don't see how direction would matter.
Processor heatink/heatpipe isn't the issue here. It's the heatpipe running from the NF4 chipset to the heatsink. In Lian-Li cases, the mobo is mounted upside, putting the chipset at the top, higher than the heatpipe. Taking into consideration that heat or warm air rises, in this case the heat from the NF4 isn't going anywhere.
I also have the Asus Preium and Lian Li V2100. I had to remove the heatsink+heatpipe.
Then how does a Big Typhoon from Thermaltake work to remove heat from the processor.
A processor is mounted on the mobo which is then mounted in the case vertically. The Typhoon then stick out to the side running paralell. If the heat rises theory worked then the Big Typhoon and other heat pipe heatsinkts that run up to the heatsink would not work, because the heat would rise up vertically instead of to the side.
Heat should still follow the pipe weather it is upside down or not. Heat a metal rod with a torch I don't care if ya hold it upside down, sideways, diagnol, the rod will get hot not just the part pointing up.
Older types of heatpipes would not work very well against gravity, but newer ones do not rely on gravity for the most part and so should work at least decently in most orientations.
ok in short distances heat pipes work acceptably upside down due to capilary action.
Longer heat pipes, like the ones going from NB to the heatsink up there, will need to be the right orientation. Capilary action is not going to work well enough upside down over longer heatpipe runs. sorry.
The difference is the BT has active cooling on it, rather than just a heat pipe/sink.When people remove he heat pipe and put a HSF on it, it works fine. The issue is, since the NB is already at the top and heat rises, the heat pipe is also absorbing the heat produced by other components which has risen. Since there is no fan on the NB, the single heat pipe simply can't dissipitate all the heat quickly and efficiently.
The issue isn't in which diresction the heat pipe is located, it's due to it's location, it's absorbing more than just the NB heat.
heat can easily go an the oppsite direct in a heatpipe( heat rises). the problem with that is that there isnt a good place for it to go. heatpipes like the one on the asus usually have a bigger copper assembly at the top for better transfer of heat to the air. if you had the a8n32 upside down the heat from the mosfets would be going to the top ( the small block over the sorthbridge) The south bridge is also in a place where it would be diffacult to have a fan to actively cool it so if you have a wtx or btx sstyle way of mounting the motherboard i woouldnt recomend the a8n32
Thank you for the explination, yours is the only one that makles sense and I can see why it would need a better solution then. Thank you.
