Heatkiller 3.0 and S1700
magoo
Im considering using my Heatkiller 3.0 on a new build with a S1700 Intel cpu. ie gen 13 or 14 Intel. I cant find anywhere that says yes or no to being able to use the S115x hardware. I dont see any adapter kits anywhere. Maybe it cant be done?
https://shop.watercool.de/CPU-Kuehler__1700
Those are the only coolers that they list as compatible with lga 1700, you might have to upgrade to a Heatkiller IV if they do not sell the adapter separate.
Best suggestion is stated above. Contact watercool directly and see what they can do for you.
Thank you.
I indeed looked through their website.
I even sent a support request in last week but Ive not heard back .
I know that my current AM4 kit will fit AM5, but I cant find anything regarding S1700 backward compatibility.
My Heatkiller 3.0 are solid blocks. Ive had them since they were released.
I cant see buying a new block for a 3 degree delta, but if I go Intel I just may need to go HK IV......
